f150 draining vst
  • f150 draining vst
    i have a 2008 f150 with about 200 hrs on it.i have never drained the vst tank.should this be done on a regular bases. thanks in advance for any replys.
    The fuel filters will first place to check if find lot of water in them then drain VST as well.
      its wise to clean the VST every now and then as if you dont run your motors that often there seems to be some water residue in the VST and it will start causing problem later so its wise if you have time do give it a clean but be careful not to damage the gasket otherwise you will have to replace it or else you will need vaseline to reseal the VST if the gasket is good
