i have changed the comp pump ,TPS,switch,and filter plus the spring diaphragm on the low pressure pump,cleaned the VST and i have also changed the fuel line and put new primer bulb ,
all these problems was shown on the yds machine,have replaced everything but still i get intermittent stalling at high speed
compression is even in all cylinder at190kpa
fuel pressure is 100%
injector rail pressure is above 60%
have replaced new injector as well
iam too busy just need help if someone knows what else can be done to get these motors going good of will they end up being good anchor
thanks
thanks
