Any suggestions?
1985 150etlk automatic oil pump problem
A service manual for your motor and reading the posts Rod has written in the past should get you where you want to go. He even said they are all about the same
If switch is working as it should then you have a problem with wiring or the oil module would be my guess. testing is the best way to find out
