Runs Good till 2,100 RPM under load, Will not climb any higher,
It has been getting worse, In the past I was able to shut it down then restart it and it would be fine until I idle around then it would act up again when I throttle up.
Boat Mechanic cannot take my boat in for 6 weeks, I have boat trips set up.
Mechanic said its possible that its the high pressure pump.
After reading alot I gather that the High Pressure pumps do not go out, they said to clear the screens and mystery screens that lead to the pump. Any step by step procedures on this anywhere on this forum, I cannot find the screens in the service manuel exploited view, stuck. I do race offroad race cars so I am mechanically inclined, just not on outboards, Looking for step by step help, I heard there are mystery screens and hidden filters to be checked (VST/High Pressure Pump), again motor runs good until 2100 rpm, I have replaced the spark plugs just to be sure, Replaced the first main fuel filter, I imagine the check valve is not a problem, What the next item to check as I get closer to these hidden screens that cannot be found!
Help, thanks,
Help, thanks,
