Hello,
I have picked up a 4stroke F115 that has a carb head installed. I am working on the head and find that the camshaft can bind when installing the camshaft bore caps. These caps can actually move when bolts are loose. I am used to either precision bolts or dowels used to locate the caps correctly. Is it normal for these caps to have such loose tolerances.
Steve
Steve
