I have the latest generation Yamaha digital tach multi-meter with one 4-pin male plug. The pink & gray wires were not inserted into the plug when received. I understand that the gray wire (with attached pin & o-rings) should be inserted in pin 1 & the pink in pin 2 - is this correct. When looking at the plug how can I identify the positions of pin #'s 1,2,3 & 4?
I am using this meter on a 2006 F50TLR but I want to use my older harness (already installed) that has a male and female square 4-pin plug on each end of the harness. I understand I will only use one female plug to the gauge and one male plug to the engine and the other plugs will not be used for this application - is this correct?
Once the wires are inserted into the plugs is it possible to remove them? I know they lock into place when fully inserted and the double o-rings make a waterproof connection. Is there a special tool to use to remove wires from a male or female plug or can I use a small screwdriver or other tool?
My gauge did not come with a wiring diagram or instructions. Can you provide a link or pdf for these?
Thank you....
Thank you....
