I just replaced the water pump on a 2000 Yamaha V-max 200hp, took the boat out to check it, water pump is working great, but while running on plane it RPM's suddenly jumped and it seemed like the drive shaft slipped, took off again and it happened again, just alittle quicker. I feel like I must of did something wrong installing the lower unit back on, since it had no problems prior to fixing the water pump. Any help would be greatly appreciated
Motor slipping out of Gear
Thanks for your response, I thought it may be the prop and I will check it, but are there other things to lookfor? Like something did'nt get aligned back right or seated back in it's original position, are there some common mistakes made when installing a lower unit back on that I can check? Thanks again for your responseLast edited by RustyFF3; 03-03-2013, 10:53 AM.
Lower unit will not bolt back up if the drive shaft does not go into the crank properly.
But you may be able to miss the shift shaft coupling.
Always good Idea to watch carefully as you put it back together to make sure you get the shift shaft and water tube into the proper places.
with motor tilted up it gives you a better view of things as you slip the lower unit back on
