Did a search on Yamaha digital tach - multi function gauges but really couldn't find an answer. I have an older Yamaha 6Y5-8350T gauge but can not determine whether it is an E1 or E2 (It is not the E3.). The harness has a square 4 pin plug and my engine has a 4 pin receptacle. I am trying to determine whether this will work properly on my engine before connecting.
Will I be able to use all functions on the gauge or just some? If so, which ones?
Is there a way I can determine if it is an E1 or E2 gauge?
Which wiring diagram shall I use for the install?
I can provide photos of the gauge & harnesses if needed.
Thank you.....
Thank you.....
