My Tilt Trim motor o-ring seal died and has let water in. Its basically all messy inside and the brushes seized. So no contact meant that the motor has stopped working. Stopped pushing hydraulic fluid. Now I have fixed the brushes and generally cleaned the commutator inside. spins nice and free. The problem is that the shaft/key on the bottom of the commutator doesn't seat back in properly. So it doesn't drive the hydraulics. I'm guessing there is some sort of gear or something at the bottom.
Can you just take the whole DC motor unit out of the hydraulic housing, or is there a better way to line the gear/key up?
Only numbers I can find on the unit are 62Y-01 and 2D-0620. Don't know if this helps at all.
thanks daniel
thanks daniel
