Recovering fault codes
  • Recovering fault codes
    Can the multifunction display on my 2006 F90TLR be put into a diagnostic mode where I can look at the current fault codes?
    Jack
    command link,yes.
    digital, no.
    why do you think you have a fault code?
      How do I get the Comman Link to display any fault codes?
      I thought I had a fault code b/c the command link didn't display oil pressure. I have since found out on 2006 F90TLR that the CLink doesn't display oil pressure. If that is the case when in one of the modes the oil pressure scale is clearly displayed. I find it funny that they'd display a blank scale.
      What do you think?
        that 6y8 tach is used on any EFI 4 stroke and any Z or VZ two stoke from about 2006.
        your motor may not have all the functions the tach does.
        to access code functions,if applicable, depress and hold mode for 10-15 seconds.
