How do I get the Comman Link to display any fault codes?
I thought I had a fault code b/c the command link didn't display oil pressure. I have since found out on 2006 F90TLR that the CLink doesn't display oil pressure. If that is the case when in one of the modes the oil pressure scale is clearly displayed. I find it funny that they'd display a blank scale.
