I have a 30 ELF which runs very well at high speed, but slobbers at idle. It's a tolerable problem, but I don't like it because it could and should be better. Since I have been unable to adjust the idle properly, it was time for a carburetor cleaning. Having now removed and disassembled the carburetors, I find that the slow air jets (I believe these would be called the idle jets) have all been ravaged by some backyard mechanic that stripped the heads off of two of them. One of them I got out and will replace.
My question is, can the remaining two be succesfully drilled out and the housing rethreaded if necessary, or is it better to leave them both alone and just live with the rough idle. I think I can drill them out easily enough, but I'm afraid all I will do is fill the carburetor body with shavings I may never get all out. Does anyone have any suggestions as to how to approach this problem?
One last thing. Am I correct in thinking that the main nozzles are held in place by a friction fit and are simply pressed out for cleaning?
