Full Power
  • Full Power
    2004 Yamaha Outboard 90HP
    Took boat out 2 weeks ago, engine started right up but sounded like one cylinder not firing, cleared it self up in about 20 seconds did not have a problem the rest of the day.
    Took it out last week did the same thing but did not clear up. would not get on plane. Starts up with no problem just not getting full power.
    Thanks for your help.
    check:
    compression
    spark
    timing
    Plugs and wires
    if all is well with those then:
    fuel pressure/vacuum
    fuel pump for hole in diaphragm
    clean carbs and adjust as manual calls for
