I have an 07 90 H/P 2 stroke that stopped peeing. I have replaced/rebuilt the water pump already and have checked that all the water lines are clear. Im lost at what to do next. Any ideas?
90H/P 2 stroke not peeing........HELP
Maybe trace that pee tube back to the fitting on the head...might be a piece of calcium scale/deposit stuck in the fitting or the tube?...If that doesn't fix it then drop lower unit and double check everything, like that water tube grommet. Did you replace the water pump base plate(could be warn) and the plastic housing?...Are you using double-sided flushing muffs to test it?...I think those single muffs ain't so good. Good luck and let us know what you find!
Same year 90 and same problem. Same attempts to restore pee; water pump; pee hose cleared, etc.
Removed taddle-tale hose from cast-nipple on block-cover Rodbolt speaks of and inserted a small drill bit into block.
I felt a restriction just inside the hole and pushed it through. Twisting bit in fingers reamed cast-nipple's hole.
Robert Graham's first sentence above describes the problem. Scale or crud had blocked the hole of the cast-nipple on the block-cover. Now pees like brand new.Last edited by Atchafalaya_man; 02-15-2013, 12:52 AM.
Â
