Old gauges to new engine
  • Old gauges to new engine
    I don't know what to do with the two small pink leads on my 2012 150hp Yamaha. Does any one know what they go to and where do you hook up the trim lead? I have the 2004 gauges.
    then 04 package may not work well,may need some simple wiring mods on the engine.
    the two pink leads only get plugged together when using command link guages.
    make sure the tach dip switches are set for two wire trim,4 stroke and 12 pole alt.
      Thanks for the info!
