I'm planning on replacing the rubber tube (grommet) where the engine oil drains. The engine is a 2005 F90TLRD. Can the tube be replaced without removing the Apron? If not,iIn looking at the parts list and the service manual, it appears that I have 5 bolts at the top and 2 on the side, but will the plastic apron spread wide enough to slide it off the engine?
Just being cautious because I don't want to flex the apron and end up with a crack.
Thanks,
Allen
Thanks,
Allen
