Please help I have a 115 AETO 1987 2 stroke outboard and the oil pump won't stop pumping oil to main tank even after it is full and this is causing oil to leak out of the top. Any ideas what the problem could be ?
Oil pump won't stop pumping
This may not be proper to post here, but here is something from a different site. It has a troubleshooting chart and info from Rod
If you do a search like Rod said you will find info like it
forums.iboats.com/yamaha-suzuki-outboards/yamaha-200hp-oil-transfer-issues-no-automatic-transfer-440420.html
in the past 15-18 years I have seen maybe 4 bad modules.
switch failures and pinched wires maybe but actual bad modules are rare.
on the original modules,no grn/white wire to the CDI unit, low battery voltage can cause pump run on.
and we still dont know what wire colors are on your switch.
yes sorry forgot to answer rodbolt the wires are black brown red white.
i am testing it now to try and eliminate things
shorting the white and black wire does not turn off pump
voltage to module is 11.85v
the only way i can get pump to turn off is via the tilt switch inside the module.
with module disconnected there is no connection from blue wire to ground.
seems to be module problem to me but im not electronics expert so suggestions welcome thanks
carefully check the module grounds.
with the key on engine off short the white module wire to engine ground.
while grounded now measure module input voltage.
white to black should shut it off,unless the white or black is open.
I hate replacing expensive electronic parts until all other items have been at least double checked.
new module kit will come with some extra wires and 6 spark plug caps.
but... some US/CAN models have the same code 6E5
not 115A
115BET = C115TLR C115TLRS C115TLRT C115TLRU C115TLRV C115TLRW C115TXR C115TXRS C115TXRT C115TXRU C115TXRV C115TXRW (depending on serial number)
115CET = C115TLR C115TXR (depending on serial number)
