i have 2013 yamaha 115 4 strke motor i installed a lowrance lms 7 with a 120-37 cable all gauges work but trim gauge i put the pink wires together still no trim the boat didnot come with analog trim do i need to install to make it work yamaha wiring is install help larrypost
lowrence 120-37 hds7 does not show trim
then it cant show both, it can only show either the analog signal on the 6y5 style digital tach OR the digital signal on the nema buss.
thats the pourpose of the small pink wire with white connectors taped at the engine harness, it splits the signal.
you can either get a digital signal for the buss or an analog signal for the 6y5 package.
