I have a z150txrc Yamaha outboard and am having problems with tilt and trim. Up works but down does not at the helm, works fine up and down on the motor switch. I have changed the helm switch but that did not cure the problem. HELP!
Tilt and trim
Ive got the same motor and had the same problem. I tracked it down to the bend in the wiring harness at the back of my boat about 1.5-2 feet before it entered the motor housing. I just cut the old wire where it was bad and soldered the wire back together. That was 2 years ago. Havent had a problem since. Good luck.
PS i trouble shot the problem by using a multimeter and kept ohming the wire til I found an open. It was right in the bend.
