I have a 15SK that we are using a on our tender in Mexico. It appears that we have water in the lower unit. Small ammounts of oil are leaking out the vent holes just above the fins. I removed the lower unit and water pump. Parts are very hard to get in Mexico but I was able to find the gaskets (682-44315-00)for both sides of the water pump and the seals below the impeller(93102-20484). There is some kind of bushing just above the seals, I think Yamaha calls it a oil seal cover(682-45344-00) off? That part is not available from the Yamaha dealer here in Mexico and they say it could be several months to get one.
I am fairly sure that the pump is pushing water into the lower unit thru these seals. I pulled the shifter rod boot and it appears to be free of cracks, so I dont think water is geting in that way. There is no sign of leakage from the prop hub. Help!
Mike
Mike
