I'm new on this site and I owned a 115hp 2stroke for 4 years now (used) and not had one single problem (knock on wood). I was reading on all I could find on the 115 vs 130 motor. I even cross reference both factory parts online and they are all identical with each other. There was one larger carb jet available for both motor but besides that both parts had the same part#s. The rev limit for the 115 is recommended at 5500r's and 130 @ 6000r's. Could this be caused by different ignition setting? Maybe the timing has been advanced for the 130 and retarded for the 115. Does anyone have the ignition timing for both motor? And how do you correctly check for timing?
If anyone could shine some light on this subject it would be greatly appreciated.
