Yamaha F15 rectifier
  • Yamaha F15 rectifier
    I bought the charging kit for my 2011 Yamaha F15C. The guy at the dealer said that the install would be obvious... that there would be two bullet plugs that I just plug into.
    When I opened it up, there are no unattached electrical plugs to connect into. So, before bringing the motor up to the dealer, thought I'd ask if anyone has done this before and if I have to look underneath something, or unplug something?
    The rest seems straightforward... just connect the ground and bolt to the engine. Just need to find the right plugs.
    Secondary question... where would I find a shop manual for this motor? I've looked around a bit and cannot seem to locate one easily.
    Thanks!
    Should be two green wires coming from stator that connects to regulator.
