Unit is a 2002 Yamaha 50 TLRA. Just finished cleaning carbs and installing new clear OI lines between checkvalves and intake manifold. Had the oil tank off and refilled with fresh oil and topped it off. When key is turned to ON position, buzzer sounds and stays on until switch is turned OFF. Mixed 50:1 in fuel and ran a few gallons thru engine after I saw the oil level go down in the oil tank so I know the OI is functioning. Engine runs like a top.
I did get the oil tank ground wire remounted under tank bolt. Can you guys give me an idea why the buzzer sounds as soon as key is turned to ON position?
How is the alarm activated? By a short to ground? Inherited the engine and do not have the owner's manual. Next step is to order clear oil line for oil tank to fuel pump.
Thanks, Young in New Orleans
