I have a pair of 1999 150 OX66 EFIs that need the lower unit seals replaced.When cleaning the area to replace water pump noticed that the spring on the seal under the water pump was in pieces. The question I have is what direction is the seal under the outer seal? are the seals back to back or are both faces[side with spring] looking out away from the unit and are the prop shaft seals installed the same?
Thanks for you time
Don
Thanks for you time
Don
