Wondering if anyone knows where to get a manual for a 60ce I have a few problems that could be solved with a manual
Yamaha 60ce 2 stroke wont turn off
yep but to check if I can help you I need manely the code # and not so importat but can make the diference the serial #
check continuity from engine block the black wire at keyswitch,then black to white acrossed the switch(key off) then white from keyswitch to white at CDI.
should have continuity.
ÂÂÂÂÂÂÂÂ
