Motor will not run except in emergency mode an blows excessive blue smoke and shuts down at 1300 rpms had to idle all the way ramp ran perfect last saturday any help would be greatful thanks
2000 90hp yamaha boat motor
Search for 90TLRY for suggestions
Hi, Sounds like the carbs are gummed up on the bog down and having to use the emergency valve to get it to run. This engine has the prime start also.
I would carefully pull a carb and inspect the bowl - if there is crud or gum, that is probably your problem. Try giving the carbs a good cleaning. See my post on doing this. Search 90TLRY in the forum and you can probably find it.
Good luck.
If you leave the "emergency mode" red lever in emergency mode (redundant?), the motor will blow blue smoke and will not run other than in idle.
The "emergency mode" red lever is for starting only. It works in place of cold choke system. Once started, you have to move the lever back into normal mode. If the motor stops running, you have clogged carb problems.
