My 2001 150 horse motor does not start or hard to start. Will probably start after many tries or I had to use starting fluid after it has sat for 3 or more weeks. Usually after just one week I can start it with two tries. However even if it starts, it would warm up a little bit/ idle then it just shuts of like it was not getting enough gas. I already cleaned and put in new carb kit. New owner to used motor or boat period.
2001 150 Horse V6 hard to start when cold.
so are you saying i asked a stupid question, or you are asking a stupid question, there are no stupid questions, they are asked because you do not know the answer, there fore a good question. there is no kit, just look at it, watch it work. see what it is doing. once you do this then you will know what to do. have some one operate the choke while you watch it..
Originally posted by Cy Thao1972 View PostThank you so far I will try all of the suggestions. I was referring to myself about the stupid questions because they are so basic to you guys but brand new to me.
me?
Nah, I was born with the knowledge.
actually I just done this for about 40 years.
make sure the 3 choke plates are fully closing.
quick test is to try a cold start with the manual choke on.
sometimes the battery OR battery cabling is weak enough that the choke wont stay fully engaged while cranking.
correct starting procedure should be about like this.
tilt engine down.
pump primer bulb to fill carb bowls.
advance throttle lever slightly(target is for it to start at about 15-1800 RPM)
turn key on.
depress choke switch.
while holding choke switch on crank engine.
started off in my dads wrecking yard at about 7.
then on to a 3 year vocational automotive program at Hogan high and san marin high and then murphy high.
did the auto thing until about 1984,also picked up automachining.
then programmed and set up CNC lathes and mills for GOEX,1988 joined the gray canoe club as an FCSN,was placed on the PRDL in 1995 as an FC2.
thats when I started doing outboards full time.
been certified for Tohatsu,suzuki,honda,force,merc/mariner,volvo,mercruiser, and made yamaha master tech in march of 06.
now I am ready for another carrear.
maybe rum taste tester for Baccardi ??
