I am rigging the new to me 99 ox-66 250. Does anyone know where I can find the rigging guide? Either to just read as PDF or download?
I am running the multi function speed fuel management gauge, if I go with the multi function tach will that also cover water pressure or do I need a separate water pressure gauge?
Also what is the best way to hook up 2 batteries? 1 set of battery cables from motor to 2 battery switch and control them via switch or run two separate battery cable from each fuse on the engine to each battery? I understand with each battery wired direct to engine fuses it will maintane the charge on both batteries but yu will have no on and off switch electrically. Verses a battery switch you can just switch to off?
Last question, if I decide to run two ox66 engines. My boat can handle 2 25" motors. I currently have one normal rotation 25" and one normal rotation 30" motor. Could I just replace the mid section and lower unit on the 30" motor and have a counter rotating 25" motor or is the counter rotation in the motor not jut the lower unit?
Thanks again for the great site and all the help!!
