excessive two cycle oil consumption
  • excessive two cycle oil consumption
    I am using an excessive amout of 2 cycle oil in my 1998 225hp outboard motor. Can you tell me how to correct the problem
    is linkage hooked correctly ?
      like JB123 said, check the linkage for proper assy... the link rod is bad about breaking and falling off, also on the older engines i have had to replace the mechanical oil pump due to the seal in the back of it leaking oil into the crankcase causing excessive oil consumption...
        can we get a model number?
