Well i had stated that i was having trouble with the motor setting the alarm off.And i changed the plugs and it runs up to 4500rpm's fine but if you go up to52oorpm's it sets off the alarm starts missing alarm goes off.turn off engine for 2 minutes and alarm is off and ready to run again.Blows my mind.I have changed the water pump empeller,Thermostats,plugs.Seems to the temp rises like restriction of water .Before i changed the plugs it bog on take off.the plugs that i changed out 3 of them were wet one dry burn.If you'll have any thoughts if love to hear them.
back again with the 115yamaha alarm
So I finally figured out my overheat alarm problem after changing temp sensor and water impeller twice took foot off 3 or 4 times trying to figure out what is going on and pretty much giving up! It was my starting battery, it must of have a short in it. For over 6 months I fought with this and the battery finally starting dying the last two trips. No issues with battery holding charge before now but it had something wrong inside shorting out at high rpms.
