First post! Thanks in advance for the help!
The trim cylinders were leaking so I replaced them. Ever since then the tilt cylinder is spongy, (Obviously air). No matter what I do I cannot get the air out. I was going to remove the tilt cylinder and replace the o-rings and refill the fluid to remove the air.
Do they still make the spanner wrench for this and where can I get it. Tried other ways but with no luck!!??
Any other suggestions would be appreciated!
Thanks!
Frank
Thanks!
Frank
