how do you clean o2sensor on 250 saltwater series 98,99
clean o2?
Here's the article explaining the O2 sensor cleanup.....
http://www.boatsetup.com/O2sensor.pdf
You'll need the new gasket for the sensor mount (p/n 68F-W1135-00-00 ($13)), and use a good torque wrench when you reinstall all the bolts so everything is evenly torqued. You can remove the O2 mount block and then place it in a vise (don't damage the mating surfaces...) and unscrew the O2 sensor with a 22mm open wrench. After a good cleaning test the sensor with a propane torch and digital volt meter (explained in the article...) to see if it's working satifactory or you need to replace it...).
Mike........ Miami, FL
ÂÂÂÂÂÂÂÂÂ
