Tachometer compatibility
  • Tachometer compatibility
    I've found a tachometer, hour meter and trim gauge that was pulled from a boat that ran a Yamaha 2 stroke 115HP outboard. The tachometer has the oil indicator lights at the bottom showing low/high. Is it possible that this tach can also be used for my 2004 F60 outboard? It's an analog tach - and I thought I read that the oil indicator could show either low level in the reservoir (2 stroke) or low pressure (4 stroke).
    So, would this work? I hope the answer is yes! Thanks, Chuck
    most lily not.
    most yamaha tachs before 2001 were not 4 stroke and two wire trim sender compatible.
