2012 F90 water pressure and temperature sensor location
  • 2012 F90 water pressure and temperature sensor location
    Searched the forum but cannot find the locations for the water pressure and temperature sensors on the block for a 2012 F90?
    depends on what guage package your going to use.
    then you have to look in the rigging guide.
      Yamaha Pro II water pressure gauge and 688-83667-00 sensor on a 2012 F90
      Found a plug with a red gasket on the starboard side of the block but nothing on the port side of 2012 F90 Yamaha outboard. I want to install both a Pro II pressure and water temp gauge on the motor. Does anyone have a pictorial that shows the proper locations on this 2012 motor?
        Here is diagram,
          Thanks for the diagram. How do you hookup both the water pressure and temp sensors with only one plug?
          Thanks for the help!!!
            there are two plugs, one for pressure one for temp.
              2 plugs
              According to the diagram, there appears to be only one??
                What is the normal operation water temperature?
                  Thermostat opens at 136-144 degrees and overheat warning will activate at 194 degrees.
                    I'm in the process of installing a jack plate and water pressure gauge on my 2011 F90. Do I put the barb fitting into the port under the oil filter?
                        Thank you for the confirmation!
