Can anyone tell me where the poppet valve & thermostat is located on a 1986 yamaha outboard prov150. we have searched every website possible with no results.. Thank you in advance
1986 yamaha outboard poppet valve
Thermostats are in top of heads, pressure control valve is at bottom of rear exhaust plate with large hose attached to it.
It's hard to get to it being down in lower cowling but not that bad.
Poppet
Here
1986 PROV150LJ Yamaha Outboard CRANKCASE CYLINDER Diagram and Parts
Best to replace grommet valve spring and gasket-not expensive and then you know.
