I have a 2000 250 OX66. I would like to add a water temp sensor and a water pressure sensor. Unfortunately they appear to occupy the same hole. Is there anyway to install both?
Both Water Temp & Water Pressure Sensors
Revenge25,
Your V-6 block motor should be similiar to my V-4 (C115) in that there is a water jacket plug on top of both cylinder banks. You can install a temp sensor in one, and a water pressure sensor in the other. You're just gonna have to be careful about clearance between the top of the sensors and the inside of the top cowling (hood).
I mounted my temp sensor on starboard side - it is a little higher than port because of the offset of the pistons on the crank. I had to cut out a relief area on the inside of the hood - the part that is an insert just under the outer shell.
You can check clearance by rolling up some play dough and shaping into a cone and setting it on top of the sensor - install hood and remove and see if the cone has been pressed, and voila! There's your clearance! (pretty high tech, huh?) [img]smile.gif[/img] .
Good luck,
Ken K
