High Temperature alarm?
  • High Temperature alarm?
    I have recently had a high temperature alarm go off only when running at idle or low speed. I have replaced the water pump and the thermostats and still it continues. I am worried that it could be the Exhaust corrosion problem I have been reading so much about. The engines are 2002 225hp Four Strokes. Any other ideas of what it could be?
    Thank You
    Captain Chris Wolowitz
    Check to see if PRVs(poppits) are sticking open
      Ok will do. Tried everything else why not.
        there is a good article in this months towboatUS magazine concerning the F200,225 and 250 corrosion issues.
        next I hope they address the F150 balancer issue.
          BoatUS Magazine: Yamaha F225 Corrosion Complaints | October - November 2012
          Sure hope it is not the corrosion issue for you, but they talk about motor smoking and/or blowing dip stick out due to eating through oil pan also
            and that thin flat plate cracks and dumps water pressure,most noticable as an alarm at idle speeds.
            ex kit is about 650 dollars and takes about 6-8 hours to install.
              Well, here it is. Both my Yamaha 225's have succomd to the manufacturers defect Boat US is talking about. Only 850 hours 2002. Both corroded with craters and holes in the DRY exhaust area. Big dollar repair. Who do I send the bill to??? Yamaha!
                if ya dont like that bill wait until you see the one after the cyl heads corrode.
