Help with 2002 Yamaha Vmax Positive Battery Cable Connection Point
  • Help with 2002 Yamaha Vmax Positive Battery Cable Connection Point
    I'm rigging a 2002 Yamaha 225 Vmax EFI and I'm curious if there is a schematic for where the battery cables connect to the motor?
    It looks like the battery cables were originally connected with the negative on the side of the starter and the positive in the box beside the positive line that runs to the starter.
    The negative bolt looks fine, but the lug bolt for the positive that is beside the starter hot wire looks very small for that heavy Yamaha positive line to hook in there and the cover to fit and snap closed.
    Do I have the right positive connection point or am I missing something?
    Positive battery cable connects to starter relay post(large post opposite of starter lead post), negitive connects starter frame.
      Do you have a diagram on that?
      Do you have a schematic or diagram for that? The post I saw opposite the starter relay was small, so I was confused.
        No the manual doesn't have a drawing of battery cable connections.
