waterpump impeller
  • waterpump impeller
    I just bought used 15hp 1985 yamaha. Supposed to have new pump but won't pee out exhaust. All lines appear clear, checked out impeller and looks new. Which way should blades run on impeller? Thought maybe it is upside down.
    Driveshaft turns clockwise so blades would be turned accordingly...you may should consider replacing the entire water pump(kit)
