still not running right
  • still not running right
    203 z200 hpdi
    warm motor
    rpm 650
    fuel pressure 690.52 psi
    atmospheric pressure 30.1 in hg
    timing btdc 4 deg
    o2 sensor 0.00 v.
    tps .60 v
    throttie opening 2.0 deg
    water temp 131.9 f
    intake temp 101.3 f
    still does not want to run when 1 st started
    all filters new
    plugs new
    o2 sensor new
    sync & link done
    what should i check
    Hopefully Rodbolt will offer his expertise....
      O2 sensoV way off.
      dang that intake air is hot.
      engine temp indicates its warmed up.
      TPSV slightly off.
      redo the link and sync per tech bulliten not service manual.
      ign timing is rather high for a warm motor.
        got it fixed put all new injectors in and it runs great now,thanks for the help
          glad its running better.
          still does not negate the fact the O2 sensor voltage is way way out nor the TPS V is almost out of range.
          fix the last details and it will be sweet.
            i don't have the #'s with me today but they all looked ok after the injectors were in
              where do i get the the link and sync per tech bulliten from
