oil leaking from carb
  • oil leaking from carb
    I have a 1998? yamaha 150. Oil leaks from the tank on the side of the engine out thru the lower carb. What would cause this? Would I damaage the engine if I bypassed the low oil sensor and simple added oil to the fuel instead of useing the oil injection system/
    thanks for any help you can provide.
    simply fix the problem.
    its either not shutting off the transfer and filling the air box or the inline check valve to that oil port is leaking.
      How do I check those things?
