My 2003 4 stroke F25elhb lost power suddenly last week. I was running at 3/4 throttle and backed off the throttle to coast into shore and the motor stalled, then would't start. With much fuel bulb pumping the motor finally started but ran only on one cylinder. I have pulled plug wires and the engine starts with the top wire off. I have changed the starting coil but no help. Changed plugs, nothing. The timing belt is loose, but there is no adjustment. At this point I am operating on the theory that the timing skipped a tooth and that is why there is only one cylinder firing.
Anyone have advice on diagnosing the problem, or replacing the timing v belt, like an easy way to accurately locate top dead center on the # 1 piston?
