Yamaha F225TXRB tilt/trim issue
  • Yamaha F225TXRB tilt/trim issue
    I have a 2003 Yamaha F225TXRB. I removed the tilt trim unit because the fill cap was stripped out and water got into the system. I pulled all rams and replaced all seals on the unit. I removed the electric trim motor and was going to remove the pump and unfortunately removed the 69J-43843-00-00
    SCREW, VALVE LOCK's to clean them out and did not note the position that they were in. I put the unit back together and tried bleeding the system and noticed that the tilt will extend and retract but the trim cylinders will only extend but not retract. I notice the electric trim motor will bog down like it is being restricted. I believe its because i messed with those screw valve locks. If there is any hope on salvaging the pump so I do not have to replace it that would be great. Thanks for the help.
    If don't have the service manual then look at parts list, 2003 F225TXRB Yamaha Outboard POWER TRIM TILT ASSY 1 Diagram and Parts
