idle
  • idle
    i have a 2003 200 hpdi when cold it will start up surges and dies,after running at a faster idle about 2 min. it will start up and run fine,what should i check,runs great at top end,and all day after i run it
    Need to do a sync and link, check TPS setting and check thermo sensor.
      where is the thermo sensor and how do yiu check it
        anything i should check
          It's number 23 in this link 2003 Z200TXRB Yamaha Outboard ELECTRICAL 2 Diagram and Parts
          Heat it up in water and check resistance,
          Engine cooling watertemperature sensor resistance
          Black/yellow (B/Y) –
          Black/yellow (B/Y)
          5 °C (41 °F): 128 k
          W
          20 °C (68 °F): 54 - 69 k
          W
          100 °C (212 °F): 3.02 - 3.48 k
          W
