shift linkage rod 1988 25hp
  • shift linkage rod 1988 25hp
    hello guys.
    i just purchased a used 1988 yamaha 25hp two stroke engine. 25SG
    it needs the shift rod that goes from the gear shifter on the front of the cowl, by the tiller handle, to the sector arm under the cowl.
    in this diagram it shows everything but the rod that i need.
    1988 25SG Yamaha Outboard CONTROL ENGINE Diagram and Parts
    i need the rod that connects to part #22..
    do you guys know where i can get one ? i have searched the web and have not been able to find one, thanks
    never mind guys, i think i just found it. been searching for two days and finally ran across it. im pretty sure its item # 35 in the diagram
    1988 25SG Yamaha Outboard STEERING Diagram and Parts
    im sure i will be on here asking more question.
    thanks guys
      ordered a shift rod from my local marine supply store. the plastic part that the rod screws into was broken, so i fabbed a steel one, and it now shifts as new..
