impeller
  • impeller
    Accidentally started my 2011 225 4-stroke out of water for 1-3 seconds.Tell tale stream seems fine.Did I get lucky?Should I replace the impeller and have her looked at?Dave
    Only God can answer that.....
    You can wait for his answer, or simply check to be sure.....
    1 - 3 seconds can be another mans 30 - 40 seconds.....
      impeller
      The boat/motor is kept in a slip and was used earlier that day.Since I come in the slip and tilt the motor up when I tie up at the slip,isnt there residual water still in the lower unit that could have protected or at least lubricated my impeller during the accidental start up?1-5 seconds tops.I plan on inspecting and changing the impeller next week(its about due anyway).I just wonder since the tell tale is streaming fine can I run her for now?
        I would say go for it, if is had been sitting for a long time then it may have hurt it, but if you get some type of alarm then you know
          Dry start
          Man I wouldnt sweat that...Did you start on the hose or in the water again? I bet it pee's like it did before you did that..Just dont do it again...
            IF it is peeing you are OK.
              Thanks all.Theres nothing like a second opinion.
