Accidentally started my 2011 225 4-stroke out of water for 1-3 seconds.Tell tale stream seems fine.Did I get lucky?Should I replace the impeller and have her looked at?Dave
impeller
impeller
The boat/motor is kept in a slip and was used earlier that day.Since I come in the slip and tilt the motor up when I tie up at the slip,isnt there residual water still in the lower unit that could have protected or at least lubricated my impeller during the accidental start up?1-5 seconds tops.I plan on inspecting and changing the impeller next week(its about due anyway).I just wonder since the tell tale is streaming fine can I run her for now?
ÂÂÂ
