the 68f number supercedes to the improved 60v number.
ALWAYS use the correct oeticker clamp. DO NOT use a worm screw style clamp.
and its a post VST also known as the medium pressure filter,
Thanks for correcting me on the pre- and post-VST Rodbolt. I think I understand from what you wrote that they are the same exact filter, with just a different identifier? And yes, I did take your advice from a long time ago and I bought Oetiker clamps and a pliers. Thanks again~
