Turns out that the T25 does not support any function on a multifunction tach except the tach.
T25TLRD Tach installation wierdness
that connector you posted a picture of is what supports the other functions on the tach.
the trim/oil harness is what feeds visual indicates for overheat,oil and trim.
the tach signal feed is part of the 10 pin main.
the harness you need came in your kit,use it.
ÂÂÂÂÂÂ
