Engine bogs when you first give it gas and then takes off and plains. Iv'e cleaned carbs, new gas, new fuel pump diaphragms, new spark plugs . new gaskets..What do you think about the reeds not working. Help Please
1998 30hp Yamaha SG
Originally posted by Leafman1 View PostI had the same problem on a 25 3 cylinder 2 stroke. I replaced my fuel line, bulb and added a water/fuel separator and that did the trick. Over time the inside of the fuel line brakes down and will clog up filters and orifices.
